Driver brake light turns off when activated with headlights on
Old Feb 8, 2018 | 05:20 AM
WTaylor05's Avatar
6th Gear
Default Driver brake light turns off when activated with headlights on
2004 Disco, no electrical problems other than this:
When the headlights are off, brake lights activate as they should. When the headlights are on, the warning lights work as they should, but the brake light on the driver's side turns off when brakes are applied. Changed the bulbs, that didn't work. Figuring it's going to be grounding issue. Does anyone have a wiring schematic for this vehicle? Also, what is a good DIY home repair manual for these things? Doesn't look like Haynes has them for the gas V8s. Thanks!
Old Feb 8, 2018 | 06:07 AM
mollusc's Avatar
Look for a thing called the RAVE -- there are links to it all over this site.
There's also a document called the D2 Electrical Library that contains a lot of essential information.
Old Feb 8, 2018 | 10:07 AM
Dave03S's Avatar
I recently had an intermittent rear drivers side brake light which was solved when I cleaned the contacts in the socket. The two spring loaded strips of metal were rust colored.
Old Feb 8, 2018 | 11:01 AM
WTaylor05's Avatar
6th Gear
Appreciate it. Thanks guys.
Old Feb 8, 2018 | 08:35 PM
number9's Avatar
The wiring prints are in the Discovery 2003MY Electrical Circuit Diagrams. The DISCOVERY 99MY to 03MY ELECTRICAL LIBRARY has much useful information. Both documents are from the larger LR Rave pdf.
huliah
Jan 4, 2016 02:15 PM
dparham
Jan 21, 2015 02:36 PM
Lord Wert
Jul 4, 2013 07:52 AM
03discoman
Jul 12, 2010 07:03 PM
Drnknmnky13
Jul 5, 2006 06:54 PM
