Drivetrain issue at low speeds
Old Dec 2, 2024 | 10:55 AM
OleMissRbl's Avatar
Default Drivetrain issue at low speeds
I have an intermittent issue that happens from stop, typically while turning. It sounds like a whining belt noise, followed by almost no acceleration, like I’m holding the brake and accelerator at the same time. After a few seconds there is a clunk noise, and everything returns to normal. I thought my front Tom Woods propshaft was the culprit. I put the stock propshaft back on, but after a month, it just happened again. I was in a drive thru, and would barely move forward while pressing the gas, followed by not moving while pressing the gas, then the clunk, & back to normal. Any ideas?
Old Dec 2, 2024 | 12:33 PM
Richard Gallant's Avatar
Torque Convertor,low transmission fluid sounds most likely from the description
Old Dec 3, 2024 | 11:48 AM
OleMissRbl's Avatar
I put a new filter & gasket on this summer, but just double checked, & the fluid was running out when I unscrewed the fill plug.
Old Dec 3, 2024 | 11:51 AM
whowa004's Avatar
was it running when you did that? Fluid check on these is not as simple as cold, motor off and unscrew.
Old Dec 3, 2024 | 12:23 PM
OleMissRbl's Avatar
I followed the procedure on one of the sticky threads for the maintenance a few months ago, but it was not running when I just rechecked the level.
Old Dec 3, 2024 | 12:27 PM
whowa004's Avatar
search again for how to check level. Not running will not be accurate.
Old Dec 3, 2024 | 01:07 PM
OleMissRbl's Avatar
Thanks for the reminder. Ran it through all the gears with the engine running and rechecked. ATF was still slowly coming out of the fill plug. I added another few pumps to replace what ran out.
Old Dec 3, 2024 | 05:45 PM
@OleMissRbl Well it still sounds like a torque converter, have you fitted a CDL ?
Old Dec 3, 2024 | 06:51 PM
OleMissRbl's Avatar
No it’s an ‘03 with no lockers, but I was planning on having a local shop put in a CDL from an ‘04 after the new year. I’ll probably grab the torque converter from the same ‘04 that’s at my local junkyard, just in case. Thanks. I’ll update when I get everything sorted out.
Land Over
Aug 17, 2020 10:48 AM
t-bone679
Nov 8, 2019 08:42 AM
RossN99
Jan 24, 2018 10:37 PM
mrjlyr
Jan 16, 2010 04:00 PM
girouardrover
Jul 16, 2008 04:55 PM
