Driving without front drive shaft? '03 D2
Old Jan 19, 2010 | 01:48 PM
rj95lss's Avatar
Originally Posted by okdiscoguy
just to clear this up, all D1's have the case and linkage that can lock. 99 to mid 01 the same case was used, but no linkage. You can buy the linkage and hook up the existing mechanism, or get under your truck and lock it manually. They did not come back with this feature until 2004, so the late 2001 to 2003 you can not lock unless you re-build the case and add the mechanism. You can not lock a 2003.
It is never a good idea to run long distances with either shaft removed. The differentials are smaller and will not hold up to the stress put on them.
Got it - thanks...
So I am buying a low miles '04 t-case with all linkage and shifter locally, then for safe measure see if i can't get a rebuild kit for it before install.
Thanks again-
Old Jan 19, 2010 | 01:54 PM
okdiscoguy's Avatar
Don't try to re-build it, it is a nightmare and it shouldn't need it. Just swap them out and install the linkage. It should work just fine.
Old May 5, 2017 | 04:39 PM
rcdoeshair's Avatar
Default 04 D2 all stock - transfercase
I pulled my front driveshaft and after reading some post, realizes that I can still drive it by manually adjusting the CDL. Everyone talked about a 10mm bolt. Is it normal that I was able to engage and disengage by hand? All I did was push or pull the rod and it worked.
Old May 5, 2017 | 06:53 PM
Alex_M's Avatar
Yep, normal. 04 was the only year that had the CDL linkage from the factory.
Old May 5, 2017 | 06:56 PM
rcdoeshair's Avatar
Thumbs up 04 D2 all stock - transfercase
Thanks for the reply Alex_M. I was a bit worried because I hadn't read anything about someone just moving it by hand.
avking
Sep 15, 2024 08:11 PM
zukilj20
Jul 31, 2011 04:20 PM
twaszak
Jun 4, 2011 09:01 AM
TripleThreat
Apr 12, 2011 08:58 AM
grandkodiak
Mar 3, 2011 10:02 PM
