EGR valve cleaning?
Old Aug 15, 2014 | 10:21 AM
aftermath431's Avatar
Default EGR valve cleaning?
I have a 2000 Disco with the 4.0 v8. I was wanting to clean the EGR valve but its sealed. Unless i'm looking at the wrong one. It set on the top back side of engine. Is there a way to clean it our am I looking at the wrong valve?
Old Aug 15, 2014 | 02:51 PM
ImQuattro's Avatar
Didn't know these rigs had EGR's.
Think you're referring to the idle air control valve (IAC).
I just spray it out with carb cleaner until clean.
Old Aug 15, 2014 | 03:27 PM
ZGPhoto's Avatar
The Td5s do, the V8s shouldn't...I don't believe...
Old Aug 15, 2014 | 05:49 PM
OffroadFrance's Avatar
You are right ZGPhoto. The TD5 uses an EGR setup. Like mine, most people in europe remove them as they are another endless source of trouble and help consume lots more diesel. (it pays just to store the EGR in the garage just in case the DOT require them to be refitted)
www.discovery2.co.uk /workshop - EGR removal
Old Aug 15, 2014 | 10:05 PM
Thanks I sprayed it with carb cleaner and now the parts inside are moving like it should. I'm thinking I should rum sea foam through the vacuum line to clear everything else out. don't no how good that will be for the O2 senors. but my disco does seem to be running smotther since I clean the EGR our whatever it's called.
kid A
Aug 13, 2021 06:14 PM
fromthebackrow
Oct 18, 2012 03:38 PM
isofast
Jan 31, 2010 01:11 PM
Doss
Mar 26, 2006 06:00 PM
karl_page
Dec 27, 2005 05:45 PM
