Electric fan option -Ford Fusion
Old Jun 27, 2022 | 05:29 PM
  #31
Greg_M's Avatar
Thanks!
Old Jun 27, 2022 | 07:41 PM
  #32
RA122125's Avatar
Banned
I think the radiator core size of the D1 is a couple inches shorter than the D2, so this fan may be a little taller than you need. I think they were about the same width, but not the same height.
Old Jun 27, 2022 | 08:05 PM
  #33
Greg_M's Avatar
Yes, you're correct. Just measured and it's too tall. Bummer.
Old Jun 30, 2022 | 07:33 PM
  #34
Sandman614's Avatar
Working on my install today. Only question so far is which outflow are the D2 radiators? *That's a dumb question* I just looked at the orientation of the tanks on the pic.. Cross Flow
Old Jun 30, 2022 | 07:46 PM
  #35
RA122125's Avatar
Banned
Looking great! You're doing a lot more trimming than I did, and it's fitting REALLY nice! You may not need the rubber seal with it all trimmed in tight like that, cool idea, nice work
Seems like you figured out the D2 radiator is crossflow, with inflow at the top and outflow at the bottom. I'm curious what kind of sensor does your controller have?
Old Jun 30, 2022 | 08:36 PM
  #36
Sandman614's Avatar
Just a little thermistor wrapped in heat shrink
Old Jun 30, 2022 | 09:59 PM
  #37
Tumbler's Avatar
I'm very excited to see more updates on this thread. Def a top 10 for me guys. Incredible work!
Old Jul 1, 2022 | 07:35 AM
  #38
Sandman614's Avatar
It's a much easier swap than I originally thought. I'll be posting temp graphs to compare once I get it done.
Old Jul 1, 2022 | 10:53 AM
  #39
Sandman614's Avatar
The temp sensor info for what I did with my setup will pertain only to the Derale PWM controller style. Other methods of controlling the fans will likely have a different type of sensor and will need to be mounted according to their specs. I would also like to let folks know the Derale is a screamer, lol. It makes a squealing noise at low fan speeds that can be a little odd at first. Like I said in my original post, I may try the DCC controller brand if I ever do it again, both for the easier sensor it has, and the lack of squealing noise it supposedly does not have. But, for what I did......
Nope don't change a thing! This thing whines and squeals like an ambulance too.. Seems like it's at it's worst below 1amp and the fans get to be louder than the whine after that point.
Old Jul 1, 2022 | 11:22 AM
  #40
RA122125's Avatar
Banned
Well heck, that's as bad, if not worse than the Derale. Good to know, and Thanks for posting that! I was curious if all the controllers did it, and it seems like they do. I've gotten used to it at this point, and find myself listening for the sound to tell me if the fans are running or not when sitting at a stop light (have to turn the radio off to hear it tho).
My controller has the loudest squeal when the fans are at their lowest RPM, then it gets quiet when the fans are at high speed. Works great, but I bet it makes people look at my Disco funny in the grocery store parking lot, lol
I'm really looking forward to seeing your temp graphs after this mod. I didn't get to do any data logging before I did mine, and I love that kinda info. What app or tool are you using to collect data thru your OBDII?
