Electrical Short Simple How to fix
Old Jun 21, 2009 | 11:39 AM
mrossipir's Avatar
Default Electrical Short Simple How to fix
2000 Disco II, blowing 2 fuses no matter how many times I replace them. Car stuck in park (although brake lights work fine, shifter solonoid is good....fuse to shifter solonoid keeps blowing). I have managed to drive the car by pushing in the solonoid pin in the shifter. Front seat forward and back fuse also keeps blowing (heated seat works fine).
I have yet to find a post expalining in simple terms how to fix and trace a short. What tools are needed and starting from the fuse how do I trace a wire for repair and what causes a wire to short (I assume shorting means the wires are touching or a ground is no longer "being grounded") due to corrosion.....any help greatly appreciated.
Old Jun 21, 2009 | 12:28 PM
Rover Chris's Avatar
a short is when positive touches ground, a light is a short just a very small one that does not exceed the current draw of a fuse, usually a multimeter will help you find a short, I like to unplug the component at the end of the circuit and then test at the fuse, this will help identify if the problem is in the component or in the wiring. locating a short is not usually a very simple task many times a fuse provides power to a few different circuits so you have to determine which one is drawing to much current and blowing the fuse. I would start looking over the schematics in the rave manual to find where the power goes from the fuses that keep blowing and then start disconnecting components that are powered by those fuses, it is generally more common that a certain electronic component goes bad then a wire under the dash shorting to ground, like the power seat, unplug the plugs going to the power seat(I would imagine that it would be in the switch but you would have to check to see where the fused power goes for sure) then unplug the fuse and test for ground where the fuse plugs in, if there is ground the problem lies in the wiring if not then the problem is either in the switch or the motors, and then continue from there. do the same thing for the other fuses that are blowing.
Old Jun 22, 2009 | 10:43 AM
Quit replacing fuses, they are there for a reason, to keep you from burning up a wire harness. If you do not know how to check for a short, then do yourself a favor and let a mechanic check it.
As for the shifter, do your brake lights work, if not, you need a new brake light switch switch for starters.
Old Jun 22, 2009 | 07:59 PM
I do have to say I agree with Mike on this one, a short can cause alot of damage to your vehicle including an electrical fire. If you are not too sure about what you are doing, I would take it in to someone who is.
CodyCasteel
Mar 31, 2013 09:41 AM
Zed
May 4, 2011 04:29 PM
chakadog
Dec 27, 2008 05:20 PM
SurfingRover
Dec 6, 2007 06:22 PM
Lebowski87
Aug 11, 2005 02:10 PM
