End All answer to stupid oil questions.
Old Aug 14, 2013 | 09:09 PM
  #221
FLA Rover's Avatar
Knucklehead at advance auto parts didnt want to sell me the L40316 for my disco. His computer said it wouldn't fit. I'm not violent by nature but thought I was gonna have to knock him out and leave the money on the counter to get it out of the store...
Old Aug 19, 2013 | 05:41 AM
  #222
Motorvated's Avatar
OK so I'm about to do an oil change on a new to me, high mile disco. Were sure on this filter? My local stores carry it, I've just never used a filter this big haha still thumbs up on it?
Old Aug 19, 2013 | 06:32 AM
  #223
I have run it on my 97 stock, and it clears, and my oil psi was good (44). Fill the filter with oil before you mount it.
Old Sep 10, 2013 | 02:16 PM
  #224
olywa's Avatar
Will a K&n hp3001 fit in my 1998 disco?
Old Sep 10, 2013 | 05:14 PM
  #225
antichrist's Avatar
Yes, if you like overpaying for a nut and racing stripes.
Wix 51515 (or NAPA Gold 1515) for about $5.
Old Oct 4, 2013 | 09:45 AM
  #226
binvanna's Avatar
Napa 1411. The Mann/Purolator filter in the OP is too long and my relocated steering damper hits it. The 1411 is shorter but much wider and more volume than the Mann. By rough estimate using outside dimensions, it has 30% more volume than the Purolator/Mann. It sells for under $10, usually 9 and some change.
Part Number: 1411
UPC Number: 765809138728
Principal Application: Allis-Chalmers, Fiat-Allis, Hercules, Komatsu, Iveco, Winpower
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 5.988
Outer Diameter Top: 4.282
Outer Diameter Bottom: Closed
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Beta Ratio: 2/20=20/35
Burst Pressure-PSI: 470
Max Flow Rate: 7-9 GPM
Nominal Micron Rating: 25
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.834 2.462 0.200
Old Oct 4, 2013 | 02:04 PM
  #227
antichrist's Avatar
I don't know if 4µ matters that much for the nominal rating, but the 51515 is a bit better. Though the beta ratio is the same.
Old Oct 10, 2013 | 03:54 PM
  #228
san988's Avatar
For all of those that does not believe in this ROTELLA 15/40 diesel oil, let me tell you that you will notice a difference (big positive one) when you do the change. I feel bad I did not do it before in my previous 7 year with my 2003 Discovery SE7
Old Feb 7, 2014 | 04:46 PM
  #229
Sophia Buscemi's Avatar
4th Gear
Smile
Originally Posted by RoverMasterTech
USE THIS FILTER. PUROLATOR #L40316. 17 microns @ 50% 1st pass. Made by Mann.
Vs. A wimpy 3001...
USE THIS OIL. ROTELLA 15/40 -OR ROTELLA 5/40 SYNTHETIC (I don't recommend synthetic to my disco customers, It seems to just pour through the crusifix seals)
2003 land Rover Greensboro service center Discovery - 30* ambient temp: - 5/30 Synthetic oil - 15 psi idle COLD, 40 psi 2500 RPM COLD - 9 psi idle HOT, 38 psi HOT 2500 RPM
Same car with mongo filter and Rotella 15/40: 38 PSI idle COLD, 66 psi 2500 COLD -
21 psi idle HOT, 62 psi 2500 HOT.
(this engine has a tired pump and worn bearings, customer was concerned with engine NVH, noisy idle was eliminated with Rotella + mongo filter.)
Land Rover Greensboro Service center
Old Feb 7, 2014 | 05:01 PM
  #230
Dan7's Avatar
Couldn't find this thread earlier. Subscribed!
