engine no start
Old Apr 6, 2012 | 03:32 PM
rswede's Avatar
Default engine no start
after running warm turn engine off let stand for a while try to start engines turns over but no start placed a gas rag in air box turn over eng still no sign of wanting to start checked for spark none let vehicle sit for a couple hours try again and it starts runs good when running any fix
Old Apr 6, 2012 | 05:18 PM
Prime candidate for new crank position sensor, it cools off and sparks return, you can pour water on it to speed that up, does not always throw codes, $70, every little spacer and nut that comes off goes back in exactly same sequence or it won't work. See attached.
File Type: pdf
Old Apr 6, 2012 | 08:54 PM
Jared9220's Avatar
Yep, sounds like the Crank Position Sensor.
Old Apr 8, 2012 | 12:13 PM
Not sure who told you to throw a gas rag in the filter box, stupidiest thing I have ever heard of. Do you realize there are 2 heated elements inside the MAF that could have flash the gas vapor and burned your truck to the ground!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
dmatranga
Feb 5, 2013 12:27 AM
vtec2403
Jan 30, 2013 05:27 AM
RoverZebra
Dec 8, 2012 04:27 PM
armyeng
Mar 8, 2011 05:58 PM
jonsimon
Jan 29, 2007 01:55 PM
