Engine Replacement- What to buy
Old Jan 24, 2011 | 05:06 AM
dpvanemburg's Avatar
Default Engine Replacement- What to buy
All,
I am interested in learning about engine replacement (can't fix the tick).
Assuming that it will be:
- Remanufactured or new (not interested in used)
- Block and heads (want to replace everything associated with the tick)
Any experience with engine suppliers?
Look forward to learning from the experience of others.
Thanks.
Old Jan 24, 2011 | 08:03 AM
sloan74's Avatar
What's the plan afterwards? on road commuter or off road warrior?
honestly I would just shop for a donor. maybe a wrecked (rear end) donor? that would be the cheapest/easiest route.
Old Jan 24, 2011 | 09:37 AM
And why can't you fix the tick???????????????
Go to the top of this section and read my sticky regarding valve train noise.
Old Jan 24, 2011 | 06:04 PM
Mike,
I have read the article about clearance of the pushrods / lifters. There were no shims in my truck. It is not clear for me how shims relate to low oil pressure. I think that my problem is that I have 7-8 psi of oil pressure. The RAVE manual says >10 is minimum. 1500 rpms brings oil pressure and the end of the ticking.
Where do you go to fix oil pressure after a new front cover (oil pump), lifters/pushrods/rocker arms/rocker arm shaft, new main bearings and new rod bearings?
Thanks in advance if you can provide any information.
Old Jan 24, 2011 | 07:24 PM
http://www.jasperengines.com/index.php
Old Jan 24, 2011 | 07:39 PM
lordmorpheus's Avatar
Unfortunately, Japser doesn't do Land Rover engines (at least for a D2), something I've brought up with our sales rep. That's really too bad, because they could probably come up with a permanent fix for every single problem that plagues these engines!
ibet7777
Off Topic
Oct 26, 2007 08:21 AM
Raiderfan
Oct 10, 2007 07:36 AM
projekz
Sep 11, 2007 09:31 AM
bmwboy
Jun 17, 2007 09:27 PM
alex of minnesota
Nov 1, 2006 11:22 AM
