Engine Running Ok Then Stalling TD5
Old Jan 22, 2016 | 10:18 AM
Stephen Disco 2's Avatar
8th Gear
Exclamation Engine Running Ok Then Stalling TD5
Runs ok for a little while then the Red "(!)" symbol comes on in the corner and eventually the yellow engine light and the car stalls.
The motor wont start after that for a little while then will start again fine and run ok until the Red "(!)" comes on again and the process starts again.
I have looked at the air intake and pipes coming off turbo ect to make sure they are all sealed and tight, Im thinking maybe fuel supply cause there is enough power.
Any suggestions where i could find a TD5 Rave Manual by any chance ?
Thanx guys
Old Jan 22, 2016 | 02:59 PM
Alex_M's Avatar
http://www.landroverresource.com/doc...hop_Manual.pdf
This rave is for both the V8 and the TD5. Almost nobody on this forum has the TD5, most of us are from the US, so we don't really know much about the diesel failures. There are a few exceptions, but they are very few.
Old Jan 22, 2016 | 04:10 PM
DiscoCam's Avatar
Look on this website:
discovery2.co.uk
This guy has fixed just about everything you can on a TD5. Take a look at the website because if I remeber correctly, he had a page and fix for the problem you are describing.
Good luck.
djsteveny
Sep 4, 2013 11:22 AM
jeffmalone
Mar 13, 2010 09:23 PM
dynomite
Aug 27, 2009 02:36 PM
Bene
May 1, 2005 04:21 AM
