facelift wiring with harness
okay, 2nd go'round with early to late headlamp conversion. 1st time, no problem. I used landyzone diagram, to the letter. this time![EEK!](https://landroverforums.com/forum/images/smilies/bmHv6Xb.png)
. i was privileged to get the pig-tailed wiring harness from paul, thought that would make things easier, but (looking for the gun to head emoji) I am popping fuses. does anyone have an "easy for idiots" diagram of the wiring, with the harness? or can you point me in the right direction? (thanks zack for your efforts, to help) I know I am overlooking something, can't figure it out. there has to be a good blue/gray to blue/gray out there.... this is the interwebby. where is it?
thanks
![Frown](https://landroverforums.com/forum/images/smilies/udbMv2o.png)
thanks
still flexing my idiot muscle here. okay all my wiring is right, checked, double checked, triple checked. I think my problem is the relay. i have 4prong accessory relay. labeled 30/85/85/87
30= power with fuse?
87= ground
85= piggy from main beam?
86= piggy from hi beam?
is this right??
please advise. i look like an idiot with this 16' cane pole, strapped to the roof rack, dangling a coleman lantern in front of me. plus my radiator is getting clogged with flying insects.
87= ground
is this right??
![Wink](https://landroverforums.com/forum/images/smilies/Uh2vXQr.png)
On most of the small relays used in the D2, 85 is one side of relay coil and 86 is the other. 30 is the "common" relay contact that closes to either 87a or 87. So in your stated arrangement that fuse would blow when relay is energized, as the path fuse - 30 - 87 - ground is connected.
![Embarrassment](https://landroverforums.com/forum/images/smilies/r8fZzl5.png)
Well, the relay normally has this embossed on the side, or you can read it with an ohm meter. Now your relay might be different.
And you would not be the first to be bamboozled by the relay drawing where the contacts may be shown energized or de-energized, depending on the draftsman (draftsgal?).
theswede
10-29-2015 01:05 AM
twilightcall
03-06-2012 03:11 PM
2003discofella
12-13-2009 03:59 PM
