Filling oil pump with oil?
Old Aug 9, 2024 | 07:08 PM
evil_goat's Avatar
Question Filling oil pump with oil?
I packed the oil pump gears with vaseline before I put the timing cover on.
Should I pour oil in here to make the pump work better on initial start-up? Or would this be detrimental and wash away the vaseline?
I will also need to turn the engine over when installing. Will this mess up the application of vaseline on the oil pump gears?
Old Aug 9, 2024 | 09:18 PM
zski128's Avatar
Don’t need to do that. I would suggest to add an oil
pressure gauge while you have everything apart. Some good videos on YouTube for the install.
Old Aug 10, 2024 | 02:09 AM
Discorama's Avatar
On a dry engine I primed the system by pumping a gallon of engine oil in through the oil cooler port with a diaphragm pump. The engine was completely installed including oil filter. It pushes the oil through the pump (backwards), filter as well as the galleys. I didn't use vaseline. Oil pressure came up right away after cranking.
308nut
Dec 6, 2012 06:57 PM
curtis d.sr.
Mar 2, 2012 03:16 PM
lwarwin
May 10, 2011 03:34 PM
Rover Curious
Aug 20, 2009 01:33 AM
dogs55
Aug 3, 2009 06:31 AM
