First long trip after all the cooling stuff completed.
Old 12-10-2011 | 10:03 PM
You might want to remove the connector for the sensor, and clean it and contacts on the sensor with small wire brush, spray contact cleaner. If there was conductive corrosion between the two contact points (green gunk), it would be a resistor in parallel with the sensor, and lower the effective resistance the ECU sees. And to the ECU, that means increased heat. With mine disconnected (different system) I get a -40F reading for coolant temp. On a D2, removing the wire should make code P0117 show up. Might try a good cleaning to remove any electrical stray resistance issue, re-check readings with Ultra Gauge.
pkppunk
08-10-2012 03:47 PM
audiS4S6
04-18-2010 11:02 PM
AK Rover
02-22-2009 08:43 AM
malmberg
12-16-2008 06:37 PM
Bluejayranger
07-07-2007 07:23 AM
Quick Reply: First long trip after all the cooling stuff completed.
