Foiled by "new" tweeters
Old Aug 18, 2020 | 05:18 PM
greisinb's Avatar
Default Foiled by "new" tweeters
I have the Harmon/Kardon system in my D2 but my rear door tweeters don't work, I picked up 2 ones off a D2 in the wrecking yard and they don't work either! Talk about some bad luck! I've tested the wiring, it's all good and I get sound out of another tweeter I had laying around when I connect it to the wiring, so it looks like I managed to become the proud owner of 4 blown tweeters. Next step is to strip out the guts of one and 3D print out an insert so I can put an aftermarket driver in the stock casing so it will still look stock.
Old Aug 19, 2020 | 07:15 PM
nashvegas's Avatar
Interesting. I have a 2000 w the HK system and it all works except these 2 speakers as well. I haven't tested the wiring as you have but it does seem suspect/similar.
I wonder if these just crap out more than the other ones? Or is something else going on.
Old Aug 19, 2020 | 08:30 PM
greisinb's Avatar
Yeah, I wonder that too, perhaps they are more sensitive to electrical problems than the larger speakers. I know the back tweeters are wired in parallel with the rear woofers as opposed to the front tweeters which are on their own channel from the amp.
Old Aug 30, 2020 | 05:07 PM
greisinb's Avatar
As a final update to close this out (I try and follow up with my posts as much as I can). I designed and 3D printed out a set of inserts for some cheap tweeters (link below) and then took out the "guts" of the factory tweeters. I then put the insert in followed by the tweeter, the fit was pretty good but I added a few drops of glue just to guarantee they wouldn't rattle around. I installed them and they sound pretty good to me!
Link to 3D printable insert:
https://www.thingiverse.com/thing:4584110
Link to walmart tweeters ($8 at time of writing):
https://www.walmart.com/ip/Power-Aco...SABEgKVHPD_BwE
CarParter
Jul 16, 2017 02:30 PM
oilspotLR
May 17, 2015 06:36 PM
blast20
Sep 3, 2010 12:18 AM
rrhyne
Jun 7, 2009 06:02 PM
