Front driveshaft greasable joint part#
Old Oct 17, 2011 | 09:58 PM
Waterfowl's Avatar
Default Front driveshaft greasable joint part#
What are the part numbers for the greasable joints in front driveshaft?
New member and new 2000 rover.thanks for your responses.
Old Oct 17, 2011 | 10:04 PM
Go to this write up. Propshaft Rebuild - Land Rover Forums - Land Rover Enthusiast Forum
Also, download the free RAVE tech manual set, includes shop, owners, electrical, wiring diagrams, etc. Link below.
Old Oct 17, 2011 | 10:19 PM
Waterfowl's Avatar
Awesome.thanks!
Old Oct 18, 2011 | 08:48 AM
Send me your e-mail address and I'll send you a PDF file on how to rebuild/replace the u-joints and centering ball as well as the part numbers of the better American made parts.
Old Oct 18, 2011 | 09:04 AM
01d2Jeff's Avatar
Just a quick tip on removing/installing u-joints - use a ball joint press! it makes your life so much easier.
Old Oct 18, 2011 | 02:21 PM
GreedyRover's Avatar
I have always used a good bench vise. Is the ball joint kit better?
Old Oct 18, 2011 | 05:51 PM
grandkodiak's Avatar
Dont buy from landrover, think i found and bitched about it orignally when i first joined, they wanted rediculous price for the joints.
after reading and consideration, buying a whole new shaft with greasables built in was way faster and not that expensive... plus you have the peace of mind of a new part thats balanced and has no wear from drying up ujoints!!
Old Oct 18, 2011 | 06:02 PM
01d2Jeff's Avatar
I would say yes, as 1)it's portable (it operates much like a pulley or gear puller), so if you have a u-joint failure on the trail somewhere, you can easily carry it with you, and 2) you're not risking the "mushrooming" of a socket (which I've done using a bench vise).
just my .02, but I haven't looked back since using a ball joint press.
Old Oct 18, 2011 | 08:40 PM
antichrist's Avatar
The link provided includes rebuild instructions and part numbers for only U.S. made replacement parts.
Old Oct 18, 2011 | 11:02 PM
Princess's Avatar
When I did mine I bought the new joints at Advance Auto with the part numbers listed here. Brought the shaft to a professional place they said "Oh you have the parts, only labor costs then." Cost $60 for the joints changed by a pro, shaft sand blasted and re painted, shaft balanced. I thought it was a good deal; saved me an afternoon of work.
TripleThreat
Jun 26, 2011 01:33 PM
JCJarhead
Mar 24, 2011 07:55 AM
JCJarhead
Mar 5, 2011 05:21 PM
asikuy
Oct 19, 2010 12:12 AM
JBEGIN
Dec 6, 2008 01:14 PM
