Front Passenger Door Wont Unlock...
I hardly ride w/ any passengers so Im not sure what/when it occurred, but the front passenger door is no longer responsive to the lock/unlock power function via the key or the button on the interface(console). If i pull it up manually while in the locked position it goes back down. I have to pull the door handle from the inside in order to unlock it. My gut tells me its not an easy fix for someone like myself. Any Thoughts or advice? Thanks
You can open the door lock actuator and replace the little motor inside it.
It will set you back about $5 at Radio Shack.
Just make sure that you get a high speed motor.
Take your old on in with you and have them match it up.
Solder the new one back in, hook up the gears and you are good to go.
RTacc
09-22-2015 04:12 PM
richierichrover
05-27-2009 09:42 PM
NWRover750
05-24-2008 01:08 PM
charlottejohnston
01-22-2008 07:18 PM
