Front Passenger Door Wont Unlock...
Old Sep 18, 2009 | 03:14 PM
seamuspg's Avatar
Default Front Passenger Door Wont Unlock...
I hardly ride w/ any passengers so Im not sure what/when it occurred, but the front passenger door is no longer responsive to the lock/unlock power function via the key or the button on the interface(console). If i pull it up manually while in the locked position it goes back down. I have to pull the door handle from the inside in order to unlock it. My gut tells me its not an easy fix for someone like myself. Any Thoughts or advice? Thanks
Old Sep 18, 2009 | 04:02 PM
BigBee79's Avatar
Mine does the same thing. I think it's the lock actuator but I haven't got around to fixing it. I need to cause I hate having to leave my wife standing outside while I get in and have to open it from inside.
Old Sep 18, 2009 | 04:27 PM
NiteTrain's Avatar
yep, door lock actuator. They're about $100 used. I took my old one out but haven't replaced it yet. It's kind of a PITA cause it's really tight in the door.
Old Sep 18, 2009 | 04:34 PM
JavaRacer's Avatar
Me three! Front passenger door. I hate it when there is a PITA fix and I suddenly have very limited time....
Old Sep 18, 2009 | 05:59 PM
You can open the door lock actuator and replace the little motor inside it.
It will set you back about $5 at Radio Shack.
Just make sure that you get a high speed motor.
Take your old on in with you and have them match it up.
Solder the new one back in, hook up the gears and you are good to go.
RTacc
Sep 22, 2015 04:12 PM
richierichrover
May 27, 2009 09:42 PM
NWRover750
May 24, 2008 01:08 PM
charlottejohnston
Jan 22, 2008 07:18 PM
ja00disco2
Dec 5, 2007 02:10 AM
