Are front and rear differential parts interchangeable?
Old Dec 10, 2015 | 07:40 PM
Externet's Avatar
Question Are front and rear differential parts interchangeable?
Planning servicing the rear differential; and have a spare front. Would gears, spacers, components in general be the same ?
Old Dec 10, 2015 | 07:57 PM
Alex_M's Avatar
I think everything is the same except for the ring and pinion which are reverse cut, but I could be wrong about that.
Old Dec 11, 2015 | 05:40 AM
drowssap's Avatar
i vote they use the same parts, but check with one of the scrapers
Old Dec 11, 2015 | 08:07 AM
Paul Grant's Avatar
If you have a complete front, rather than go through the bother of harvesting parts to redo the rear diff, I'd just put the spare diff in and pick up a rear driveshaft with u-joints at both ends. You'd never have to worry about that roto-flex coupler again.
Old Dec 11, 2015 | 09:56 AM
ZGPhoto's Avatar
They are not reverse cut.
Old Dec 11, 2015 | 10:32 AM
Alex_M's Avatar
I thought the front and rear were cut opposite directions so that the wheels turned the same direction? Does that mean that they are a direct swap?
Old Dec 11, 2015 | 10:59 AM
drowssap's Avatar
i believe what Paul was saying was yes, and if you use a rear u joint conversion kit it will drop right in and eliminate the flex joint.
I was always told they used the same ring and pinion which is why front diffs go so often,
your actually putting the power to the coast side of the gears.
but ive been wrong before
Old Dec 15, 2015 | 08:39 AM
ZGPhoto's Avatar
A few companies offer reverse cut gears for additional strength. The way they are cut does not have a bearing on how the wheels turn.
Part number for the crown wheel is the same front & rear.
moglide
May 19, 2014 03:46 AM
geek_IM
Dec 15, 2013 11:27 AM
Rover De Land
Aug 26, 2012 09:05 AM
yloDiscoII
Feb 24, 2010 10:37 AM
aussiedisco
Feb 23, 2010 07:36 AM
