Front wipers not working
Old Jul 5, 2022 | 09:11 AM
Brigh04disco2's Avatar
8th Gear
Default Front wipers not working
So i have stumbled across a problem. When i bought the car the washers were not working. So during the progress of trying to find the electrical stuff i was flicking the wipers many times. And then out of nowhere the wipers stopped working, i have took apart the stalking switch and cleaned the copper contacts and regreased them with the proper grease i used for the faulty XYZ switch which does work. I reinstall it but still nothing i hear no zooming or anything from the motor or a relay clicking like i hear when i initiate the rear wiper. Is there any common issue or any one that had this problem and can help me. Is it the motor that just stopped working or any thing else. Also i am pretty sure the fuses are still good.
Thanks in advance
Old Jul 6, 2022 | 05:55 AM
redwhitekat's Avatar
pretty sure fuses are good ? either they are or not, check them, the motor for the wipers is a weak point on these, i went thu 3, they are easy to replace but they are all remanufactured now, check fuses and check poerr at motor connection plug,
Brigh04disco2
May 21, 2022 08:38 AM
Dan7
Jan 8, 2014 10:56 PM
kilted
Jun 9, 2013 07:18 PM
hubie
Dec 17, 2011 06:29 PM
meltdowndave
Oct 30, 2009 11:05 PM
