glowing catalytic conveter, rattle
Old Sep 22, 2008 | 09:52 AM
Default RE: glowing catalytic conveter, rattle
What plug wires did you use?
Go ahead and replace the cats.
Old Sep 22, 2008 | 04:34 PM
zracin's Avatar
Had everything checked out today. Injectors, plugs are good. Cat was shot, completely desintegrated on the inside. rattled around bunch of loose peices. Had new one welded on. runs like a dream.
Old Sep 22, 2008 | 05:42 PM
Glad all is well. Did they replace both cats or just one? How much was it?
Old Sep 22, 2008 | 05:56 PM
zracin's Avatar
Both cats replaced with magnaflow. To check the wires,plugs, injectors, exhaust valves, and replace 2 cats cost 300. Sounded like a good deal to me-or did i get ricpped off. Only took a few hours
Old Sep 22, 2008 | 06:03 PM
Cats just don't fail or die on their own, they fail from contamination, be it coolant, gas or oil. If you don't find the cause, it will happen again, sooner then later.
Old Sep 22, 2008 | 06:33 PM
zracin's Avatar
Im thinkin that the damage might have been done a long time ago when I had faulty injectors. back then it even had trouble with hard starts. It must've passed the point of no return for the cats a long time ago, and just now produced noticeable problems.
Old Sep 22, 2008 | 06:35 PM
For $300 you got a good deal.
Old Sep 22, 2008 | 11:05 PM
IDAHODISCO's Avatar
You should probly inspect you front drive shaft for cracks thats a lot of heat on it!!
Old Jan 23, 2024 | 10:19 AM
DonyMaybe's Avatar
8th Gear
Mike
I'm having the same problem with overheated cat. Not driving it. Replaced the left head gasket due to leak on cylinder five.
The hot cat is on the same side of the engine. Muffler shop says the cats are good. Looks like it isn't firing on a couple
of cylindars. Should I replace the coils too?
Dony
mark wilson
Sep 20, 2011 05:54 PM
EVN137
Oct 7, 2009 09:22 AM
Rioja Red
Oct 23, 2007 09:56 PM
skewett
Jul 9, 2006 10:32 PM
n2radio
May 1, 2006 08:52 PM
