GPM flow of water pump?
Old Jul 15, 2017 | 12:58 PM
Jeff Blake's Avatar
Default GPM flow of water pump?
Stupid question.
The manual says 2.64 gallons per minute @ 1,000 rpm.
Is it safe to assume then, that the GPM reach 13.2 GPM @ 5,000 rpm? Or would the radiator restrict flow?
I'm looking to plumb in a heat exchanger for hot water and need to spec it correctly to not restrict flow.
Old Jul 15, 2017 | 02:45 PM
Alex_M's Avatar
No, because restrictions increase as speed increases.
Just dead reckoning, I'd cut that number in half and then over-spec the exchanger a little. Maybe for 8 gal
What's the heat exchanger for out of curiosity?
Old Jul 15, 2017 | 02:56 PM
PalmettoDisco's Avatar
Yes, definitely parasitic losses due to drag and obstruction. It might not be half, however, I agree with Alex's recommendation to assume half. It should be about spot on, or slightly off in your favor, for your calculations.
Friday Night Disco's Avatar
Wait...I just bypassed my heater core in the engine bay, did I just cause a potential downstream impact (besides no heat in the cabin)?
Sorry if I derailed your question Jeff
Old Jul 15, 2017 | 03:16 PM
Jeff Blake's Avatar
Perfect, the 10 plate heat exchanger will do, then. B3-12A 10 Plate Heat Exchanger with M5-.08 Mounting Studs [HX1210] | DudaDiesel Biodiesel Supplies
It's rated for 6 gpm without restricting PSI.
I'm hooking up an onboard water/shower system
edit: fridaynight, I think that could cause in increase in pressure (puts more stress on the coolant cap), and of course increase in coolant temp
Old Jul 15, 2017 | 03:19 PM
Jeff Blake's Avatar
Also, what's the ID of the heater hose? I've read that its different on the heater rail vs the firewall ports?
Old Jul 15, 2017 | 10:49 PM
Alex_M's Avatar
no, that won't cause any flow issues since its not a part of the main path.
Old Jul 16, 2017 | 01:53 AM
Confirm, bypass is okay. Just no heat.
CollieRover
Jul 8, 2016 03:33 PM
A5scott
May 18, 2015 06:34 AM
Savannah Buzz
Jul 21, 2011 08:02 PM
aerokurt
Dec 3, 2006 06:00 PM
flyinrover
Feb 24, 2006 12:04 PM
