Hard Starting
Old Aug 4, 2022 | 11:33 AM
krustacean's Avatar
Please check you Coolant Temp Sensor located on top of the intake. This sensor communicates quite a bit of useful info to the ECU. I had hard starts in the morning until I replaced this little guy. Solved not just my starts but also my temp gauge in the cluster. Hope this helps....
Old Aug 4, 2022 | 11:42 AM
Harvlr's Avatar
I’m pretty sure the little bit of fuel that dribbles out won’t cause any serious issues.
Old Aug 7, 2022 | 05:40 PM
kpd122's Avatar
Finally bothered to get everything taken apart and popped the new injectors in. Is there a way to pressurize the system without bolting everything back together? I definitely want to leak check while everything is visible and accessible. Especially the ancient fuel feed line at the bottom of the rail
Old Aug 14, 2022 | 02:41 PM
kpd122's Avatar
Just an update for anyone that may stumble on this thread in the future. New injectors were 100% the issue here - number 7 plug smelled strongly of fuel. Popped them in and it starts perfectly now.
Any wagers for fuel dilution percentage on my next oil analysis?
Old Aug 15, 2022 | 04:24 PM
Harvlr's Avatar
Oil diluted by gasoline will undilute itself when it gets warm for a while. Deliberate oil dilution with gasoline on light aircraft engines is common (at least it was when I used to work on light aircraft in northern Canada), so you could start the engine the next day. In the morning you would simply start and run the engine for a while to evaporate the fuel.
Having said that, an oil change won’t harm your engine.
DiscoRabbit
Feb 1, 2018 12:14 AM
jlayno
Apr 4, 2017 11:17 AM
PNW Disco
Apr 5, 2015 10:00 AM
98discoIN
May 21, 2014 07:58 PM
jasons
Feb 5, 2011 12:31 AM
