Has anyone pinned their own liners
Old Mar 1, 2021 | 05:56 PM
  #41
Extinct's Avatar
Originally Posted by robbygian
I hear it once it has warmed up
You need an OBD gauge that will tell you the exact temperature it starts to tick at. A lot of them don't start ticking until 190-200. Inline thermostat won't let it get that hot.
Old Mar 1, 2021 | 06:46 PM
  #42
robbygian's Avatar
Originally Posted by arains44
@robbygian like @Extinct said, it won’t be easy to find someone to pin your liners. It’s not exactly common practice anywhere but the D2 community.
That being said, it’s become a fairly accepted practice that is a practical solution to slipping liners. I’d ask around on the forum, maybe post a wanted ad in marketplace, and search the FB Groups. There’s someone who can do it for you but you may have to drive a ways.
As far as price goes, expect to pay a decent amount because whoever does it is taking on a big liability. They are literally drilling holes in your engine block so I can’t imagine it will be super cheap to pay someone.
Try to find someone who has done it several times before. You don’t want to be the guinea pig. It’s a pretty simple process, but in medical terms this would be a simple surgery but one wrong move with the scalpel it could go to hell in a hand basket.
Hopefully that helps? I’d expect to $1k or so. Top hat liners would cost A LOT more.
Originally Posted by Extinct
I don't think you could find anyone who will pin them for you, maybe a Rover specialist but anyone else is going to think you are insane. They will all want to sell you a new engine and install that. You might find a machine shop willing to take you engine block and put top hat liners in, but that part of the job alone is going to be around $1000. The pinning job takes about 8 hrs to do in the truck. Good luck!
@robbygian there are many well documented cases of liners slipping on 03-04 Discos for a long long time. I’ve read posts where people said they’ve have the truck a decade and it was ticking when they bought it with relatively low miles.
Its certainly an odd situation, and the design and apparent manufacturing issues apparently create the perfect storm to allow it to happen.
I wouldn’t be too concerned about it unless you’re seeing high coolant temperatures, a loss of coolant, or something else is indicating an issue. If it’s otherwise healthy, then I’d just drive it.
Might be worth doing an oil pressure test to make sure the tick is not related to low oil pressure. That’s cheap and relatively easy/ well documented. Just need a $30-50 oil pressure test kit. Tons of good threads on the process.
Unless you have a leak from a hose it shouldn’t lose any coolant. I’d drive it hard, get it real hot, then park it in your driveway or a garage abs leave it running with some cardboard under the front of the truck. See if you spot any drips of coolant. Find where those are coming from and you might have found your issue.
Always suspect a leak from a hose or the water pump before assuming internal issues.
I will give that a try and see what I can find, thank you for your input!
Mr. Tick
Feb 22, 2018 11:37 AM
AlanK
Apr 25, 2014 06:34 AM
5-0 disco
Aug 16, 2013 02:06 AM
TF10COML
Apr 22, 2013 08:20 PM
Carolina Tire
Oct 7, 2011 08:31 AM
