HD Axles
Old Dec 1, 2009 | 03:49 PM
Sbonomo's Avatar
Default HD Axles
Couple of questions RE: HD Axles:
I recently purchased a set of ARB's so I am going to upgrade to the HD axles. I am 90% sold on the great basin but would love any input that anyone has on another set that is priced comparably.
Second question: The ARB set came complete with front and rear HD axles from a DI (I have a '04 D2 thus the need to buy new axles). They look exactly the same as the stock set up so how can I tell if they are HD or not? I am getting suspicious that they are stock and wanted to confirm one way or another.
Old Dec 1, 2009 | 04:38 PM
D1 axles won't work on a D2.
I have the Great Basin axles from 7 plus years ago, but there are others out there to look at . Try Luck 8 as well as the Todd Co for good axles at more competive prices.
Also, make sure you install new bearings on the diffs. before installing them.
Old Dec 1, 2009 | 04:50 PM
oysterhead's Avatar
i'm curious how much you paid for your ARBs? Sounds like they're used? Front and rear?
Old Dec 1, 2009 | 06:22 PM
LANDZUII's Avatar
So you can put in HD axles with out changing to a HD diff ?
Would it not brake the weak diffs that Land Rovers have?
Old Dec 1, 2009 | 07:50 PM
Sbonomo's Avatar
I got them for $1,800 with ~15K of use (the truck had 70K total so some where between 15 and 70). The package included front and rear diffs complete with arb's installed (stock gears), upgraded compressor and the DI HD front and rear axles (like i said earlier though I am not sure how to tell if they are HD's or not). I am assuming that I can sell my diffs and axles that will cover the install. I am going to have an ARB dealer do an overhaul (replace o rings and basically check everything out etc), install the compressor and wiring ($125)and install the new axles for 300 per side. Do you think that is an ok deal?
Old Dec 1, 2009 | 07:51 PM
Sbonomo's Avatar
I might be wrong here but i think the weakest point of the set up are the axles which is why i am swaping them out....
Old Dec 1, 2009 | 07:53 PM
Sbonomo's Avatar
Thank mike i will look at both of those companies and will definately change the bearings out....I am assuming atlantic british is as good as anyone to get the bearings from?
Old Dec 1, 2009 | 08:46 PM
NiteTrain's Avatar
weakest point is the spider gears.
are all HD rover axles chromoly?
Old Dec 1, 2009 | 09:59 PM
Spider gears are the weakest point when unlocked, locked then it is the axles.
d2luvr
Jun 15, 2009 10:39 AM
okdiscoguy
Mar 12, 2009 02:45 PM
ZstHHS07
Feb 4, 2008 11:12 PM
Darover
Sep 8, 2007 09:47 AM
mowthat
Mar 15, 2007 08:05 PM
