Head gasket job done! But...
Old Oct 17, 2007 | 11:30 AM
Darover's Avatar
Default Head gasket job done! But...
Guys, if you recall from a post of mine from last week, I had my head gasket job done, and they also changed the rockers. Well......The darn thing now ticks even louder than before[:@]. Weird thing is that it ticks when warm??? I still suspect an exhaust leak at the exhaust manifolds.
guess what...it also still leaks oil[:@]another weird fact, is that the oil that I find at the bellhousing is quite a bit darker that the oil that I find on the dipstick[&:]It doesn't actually leak to the point of dropping on the ground, but when wipped dry, it gets moist within my 12 miles commute to work.
As far as the coolant goes, I know it takes a couple of days before the level actually settles and can be monitored. I still need a couple of days to confirm if it still leaks or not.
Dealer says to bring it back and they'll fix whatever is wrong, but I need your input. How could the aboves symptoms be explained ?
experience anyone ??
Old Oct 17, 2007 | 12:31 PM
Default RE: Head gasket job done! But...
Don't depend on everyone theroys, just get it back into the dealer. I would suggest if it is a D2 to power scrub the engine to get every bit of oil off the engine, them check it in a day od so, if leaking the dealer will be able to find the problem easily.
Old Oct 17, 2007 | 12:33 PM
jwfuller's Avatar
Is it coming from between the bellhousing and engine? Perhaps it is the rear crankshaft seal? I replaced a leaking one on my beamer not too long back, when I was changing the clutch.
Old Oct 17, 2007 | 01:41 PM
Darover's Avatar
Funny you ask, cause no later than last week, I removed the round cap and all is perfectly dry in there. I'll check again to make sure that the synthetic 5W30 (which is thinner than what I usually use), is not making its way in there.
And Mike, I just ask to find out the possible causes of those symptoms. It's a sure thing that its going back.
Old Oct 17, 2007 | 02:35 PM
jwfuller's Avatar
Default double post
Double post
Old Oct 17, 2007 | 02:50 PM
jwfuller's Avatar
That's cool, I've seen that cap, that's useful.
FlyingZebra34
Apr 25, 2013 08:04 AM
glassman66
Jul 17, 2012 08:31 AM
DiscoIIBrandon
Aug 13, 2010 04:15 PM
IDAHODISCO
Sep 4, 2009 11:17 AM
kjordan
Oct 22, 2008 08:21 AM
