Head Gaskets - special tools required?
Old Dec 20, 2012 | 08:38 AM
steveo2000's Avatar
Default Head Gaskets - special tools required?
Just went out to start PB-soaking manifold & hg bolts, and I'm starting to envision a few challenges:
1. head bolts at #7 & #8: doesn't appear to be much room to work near the firewall. Do you guys use some sort of universal-joint socket adapter to get leverage back there?
2. exhaust manifold bolts: they are severely rusted, and I can't imagine that getting these off will be an easy job. They appear to be 12-point bolts. I have a couple of questions:
a. what's the right tool to get these off? Are Craftsman sockets still the best out there? Any tricks to getting these out?
b. the lower manifold-to-head bolts appear to be difficult to get at. What's the best tool for that job?
3. Regarding the #7 & #8 head bolts - can whatever you guys recommend for question #1 be attached to a torque wrench?
4. I read a reference to wrapping teflon plumber's tape around the new bolts. I don't think that this is necessary/recommended, but can you guys comment, please?
5. Does removing the hood make this job easier?
Thanks in advance, guys,
Steve
Old Dec 20, 2012 | 08:56 AM
DustyLBottoms's Avatar
Use a 5/8 IMPACT socket, with a short extension & breaker bar and you'll be fine for those head bolts.
Also, while not required, it's REALLY nice to have the official rover fan clutch tool set. I had removed & installed my clutch about 10 times before I broke down and bought the tool set, it really sucks that bad.
Also, DO NOT use any sort of sealer or tape on the head bolts - just a really light coating of clean engine oil.
Old Dec 20, 2012 | 08:58 AM
Yes on hood, but not required. No on teflon tape. Small torch for heat on rusted manifold bolts plus PB Blaster soaking. Fire extinguisher at hand. Breaker bar is handy (24 inch, and maybe a cheater pipe).
Think of it this way, somewhere on the planet, under a tree in the bush of Africa maybe, another owner is wondering the same thing, and store is 1000 miles away.
Old Dec 20, 2012 | 08:59 AM
steveo2000's Avatar
Thanks! I bought one of those when I did my water pump. You're right - turned what could've been a nightmare into a 5 minute task.
Old Dec 20, 2012 | 12:54 PM
jfall's Avatar
Here are some real pictures for getting out the back cylinder head bolts..
click on the flickr links inside this page
1997 Land Rover replace catalytic converter and head gaskets
On my D2 someone before me bashed in the firewall.
That was disturbing.
But it helped too.
Pictures of D2 head gasket repair
Flickr: Landroverdude2's Photostream
For engine codes try this site:
http://enginecodemaster.com
Best,
J
apcollin
Dec 8, 2009 08:45 PM
lipadj46
Nov 15, 2009 05:59 AM
i_m_jon
Jun 25, 2009 01:56 PM
nashville rookie
Mar 5, 2009 09:48 AM
