headliner removal help and sunroof drain tubes.
I see there is a how to online for a d1 headliner removal does anyone now of one for the Disco 2 ?? I stated removing mine because I have a leak in the sunroof. I used a spray bottle and sprayed water in to the open sunroof and water did come out the underneath my disco 2 so I'm guessing they must be working somewhat but I also got water inside near the corner of the windshield. So i'm guessing a drain tube most be loss our cracked?? I started removing the headliner from the back when I got the the middle where the light and switch is for the rear sunroof I removed the light and the screw behind it but using a flash light it looks like there is a screw holding it up directly above the sunroof switch and I have no idea how to get this switch out to get to the screw?? I don't want to pry on the switch itself and the plastic around it doesn't pop off from what I see. I"m pretty good at taking things about but right now i'm at a loss.
One drain tube was broke off right where it connects to the sunroof. I used a expoxy for plastic and its holding for now. I never understood you can buy a unbreakable hair comb that is stiff but can be bent but they make parts from cheap plastic that shouldn't be. For a Land rover that just isn't right..
aftermath431
10-04-2013 10:43 AM
