headliner removal help and sunroof drain tubes.
Old Sep 30, 2013 | 08:17 AM
aftermath431's Avatar
Default headliner removal help and sunroof drain tubes.
I see there is a how to online for a d1 headliner removal does anyone now of one for the Disco 2 ?? I stated removing mine because I have a leak in the sunroof. I used a spray bottle and sprayed water in to the open sunroof and water did come out the underneath my disco 2 so I'm guessing they must be working somewhat but I also got water inside near the corner of the windshield. So i'm guessing a drain tube most be loss our cracked?? I started removing the headliner from the back when I got the the middle where the light and switch is for the rear sunroof I removed the light and the screw behind it but using a flash light it looks like there is a screw holding it up directly above the sunroof switch and I have no idea how to get this switch out to get to the screw?? I don't want to pry on the switch itself and the plastic around it doesn't pop off from what I see. I"m pretty good at taking things about but right now i'm at a loss.
Old Sep 30, 2013 | 05:04 PM
jalodge's Avatar
I just reached up through the hole from the light and popped the switch out.
Old Sep 30, 2013 | 09:20 PM
Default thanks
the how to directions I got online said to pry it out and I new that couldn't be right so I decided to try and pop it out like you said and it came right out.
Old Sep 30, 2013 | 09:28 PM
One drain tube was broke off right where it connects to the sunroof. I used a expoxy for plastic and its holding for now. I never understood you can buy a unbreakable hair comb that is stiff but can be bent but they make parts from cheap plastic that shouldn't be. For a Land rover that just isn't right..
DiscoNoisebox
Jul 15, 2022 10:15 PM
killerpav
Nov 18, 2013 07:37 PM
aftermath431
Oct 4, 2013 10:43 AM
bullhead
Jan 19, 2013 02:49 PM
mlelah
Freelander
Dec 23, 2012 12:17 PM
