heat\ac fan D2 2002
Old Jan 1, 2012 | 04:01 PM
kfisher's Avatar
Default heat\ac fan D2 2002
heat\ac fan motor along with rear air stopped working. 30 amp fuse good but no power where it plugsin? need suggestions or a wiring diagram so i can trace it out.
Old Jan 1, 2012 | 04:19 PM
Here you go. Fresh from the RAVE, your own copy awaits below at free link in my signature. Higher resolution than I can send you for a few pages. You can read color codes for wires, pin outs for connectors, and the electrical library has color pix of locations of connectors. Lots more fuses and fuse links involved.
The advantage of having your own RAVE on your hard drive or usb drive is you don't have to wait on an answer (or in my case, a SWAG - scientific wild **** guess).
File Type: pdf
Old Jan 1, 2012 | 04:25 PM
jafir's Avatar
Are you saying no power where the fuse goes or no power at the connector to the fan motor?
Could it be related to what is describe at this link:
'00 Disco II blower motor fail - DiscoWeb Message Boards
Old Jan 2, 2012 | 06:43 AM
kfisher's Avatar
No power at the fuse panel. I pulled the fuse out and tested both sides of the connection. No power on either side where fuse connects.
Old Jan 2, 2012 | 07:37 AM
Swim up stream - the fuse panel has "main fuses" in the underhood fuse box, called fuse links. They run various groups of sub fuses on the inside panel. In the drawing sent, you will note that fuse link 8 and 3 may be at issue.
Old Jan 3, 2012 | 04:55 PM
BBQ Rig's Avatar
I'd venture to say it's the same issue I had.
https://landroverforums.com/forum/di...-forums-45784/
Cheers,
jmason
Nov 17, 2013 06:39 AM
Aj6543
Nov 8, 2009 06:44 PM
jmt
Jan 14, 2008 05:01 PM
jcw
Oct 29, 2006 08:39 PM
georgery
Freelander
Aug 22, 2006 08:05 PM
