Heat problem
Old Mar 8, 2013 | 03:54 PM
gavone1976's Avatar
Originally Posted by jfall
Is there the under dash gurggle or water fall sound?
is there heat at the radiator in the front?
In the morning, make sure the coolant tank is filled to the fill line for COLD.
no gurgle or waterfall, i will have to check radiator
Old Mar 11, 2013 | 02:24 PM
gavone1976's Avatar
Mechanic says expansion tank is cracked and coolant is leaking from there.Shouldn't the heat still work with just that little bit of fluid missing?
Old Mar 11, 2013 | 08:13 PM
No, the little bit of fluid allows air/steam to rise to the top of the intake manifold and fill up the heater core with vapor. Like on your stove, the pot of pasta at a simmer is warm in the vapor above, and much hotter in the water.
Old Mar 11, 2013 | 08:42 PM
gavone1976's Avatar
OK thanks for your help everyone.I just ordered new expansion tank.
Old Mar 12, 2013 | 12:47 AM
jfall's Avatar
good work!
jmason
Nov 17, 2013 06:39 AM
chip227
Dec 20, 2011 04:54 AM
skatelove303
Jan 11, 2011 01:24 PM
Evian
May 3, 2008 05:10 PM
asmcmillin
Jan 23, 2005 01:18 AM
