Help with brake line leak
Old Mar 3, 2019 | 10:11 AM
redwhitekat's Avatar
Default Help with brake line leak
Can anyone direct me on what hoses I need to repair this small leak
it’s the 2 rear lines that come off the main unit go down on the drivers side looks like it attaches to frame than looks like they connect to a ushaped hose than continue to the rear
I see Atlantic British sells the brake hose kit but I don’t see the ushaped hoses
Old Mar 3, 2019 | 10:17 AM
Old Mar 3, 2019 | 10:19 AM
Old Mar 3, 2019 | 10:30 AM
OverRover's Avatar
If it's the hoses that are leaking you need part #: SHB101350. They are straight until you install them.
Spray the Line Nuts on the brake pipe with some penetrating oil!!!!!!
> https://www.lucky8llc.com/products/r...ne-centre-rear
If you need these hoses NOW then AutoZone has Duralast # 71083 which is a DORMAN # H620307
Old Mar 3, 2019 | 10:38 AM
Best4x4's Avatar
Yep also verify your master cylinder reservoir isn’t leaking as it can soak those lower lines. AB also sells a braided SS brake line kit that includes those smaller ones.
Old Mar 3, 2019 | 10:53 AM
Thanks guys yes I need those # 5 hoses that connect to that bracket
are you guys saying those hoses also come in the Atlantic British kit
Old Mar 3, 2019 | 10:59 AM
OverRover's Avatar
Yes > https://www.roverparts.com/Parts/ABP218
Have a look (start at 8:45) >
Old Mar 3, 2019 | 11:04 AM
bingo bingo
of course it’s gotta be the harder ones to get at
I was watching that video yesterday but didn’t make it to that point
that is a job for around May or June
not doing it in -15 Celsius
Old Mar 3, 2019 | 11:19 AM
OverRover's Avatar
Originally Posted by redwhitekat
bingo bingo
You'll be fine, just START here (Tequila helps too) >
MM3846
May 20, 2014 08:19 PM
Rovin4life
Nov 5, 2012 09:59 AM
andrew12159
Dec 18, 2009 08:05 PM
tomfraser
Dec 2, 2008 10:17 AM
Cirrus
Sep 4, 2008 08:04 AM
