Help with heater/ ac blower not working
Old Jul 31, 2020 | 01:44 AM
jodyru's Avatar
3rd Gear
Replaced EVERYTHING on my 99 DII and still did NOT work, came opon this vid,did everything in the vid and IT Worked !! Here is the vid...
Old Jun 24, 2021 | 03:08 PM
Goose405's Avatar
8th Gear
“Old” Thread but I replaced my Fuse Block in my 2001 and my blower started working as normal.
Old Jun 25, 2021 | 11:32 AM
XRAD's Avatar
common fault..the power trace for cabin blower corrodes /fails and fan gets no power....fix is to add a bypass pos power line directly from battery (with inline fuse of appropriate amperage)
Old Jun 25, 2021 | 12:24 PM
Goose405's Avatar
8th Gear
Thanks man.
I saw that fix and decided just to replace the fuse block. That did the trick and it's blowing strong now.
Old Oct 5, 2021 | 09:13 AM
Traynter's Avatar
Default Blower not working
Ref. 2002 Disco II. No blower . Hello all ! This forum has been fantastic and I sure as hell learned a lot about this issue ! Bought this Disco for 700 bucks and we love it. Living in Fla, no ac is NOT an option. And this vehicle is black. I just want to add something I didn't see here (doesn't mean it's not). After checking everything I can , changing fuse block twice thinking the yard sent me a bad one since a lot of Discos had this issue. I then looked up the wire colors for the AC/Heater blower. Then I looked behind fuse block to find they were terminated (brown red and yellow green). What this told me was that this happened in this vehicles past and they already performed a work around (fuse block). I did not see this due to not taking off the lower kick panel that would have shown me this. Someone had put in a separate fuse panel for both #6 and #7. Bottom line is you could throw fuse blocks at it all day and nothing would happen at 6 and 7. Fuse blocks are becoming scarce anyway mostly due to this issue with fans. So, I made this a much bigger issue no checking incoming power and seeing if something in the vehicles history may have been done. Just my two cents if it helps. Oh, the fuse for #7 was too small and burnt. We will see how the 30 holds up. Capt. T
Old Feb 28, 2022 | 10:24 AM
Theresonly1santi@gmail.com's Avatar
you replaced the interior fuse block ? Or engine fuse block?
Seth McKay
Aug 6, 2019 02:44 PM
scootch61
Nov 24, 2014 11:41 PM
JJones82
Jul 14, 2012 07:22 PM
LR03NJ
Jun 10, 2010 04:50 PM
Stupinder
Jan 3, 2010 10:09 AM
