help, I can't get my key out.
I am in the process of replacing my front drive shaft. I had shifted the transfer case into neutral so I could get to all the bolts easier. But know I can't get the key to turn all the way to the steering lock position, and my battery got drained from the key being stuck on. Please help.
Mike
2002 disco
120,000
Mike
2002 disco
120,000
I ordered a ToddCo. Do you have a source of supply for the nuts and bolts. The nuts got pretty torn up when I took them off. And if I'm putting on new nuts then I figured I'd replace the bolts too. Are they something I can get at a auto parts store, provided they are a equal or stronger grade? Thanks.
Mike
Mike
southfloridadiscoII
10-27-2014 09:36 AM
