help, I can't get my key out.
Old Oct 11, 2010 | 04:51 PM
Davis1978's Avatar
6th Gear
Default help, I can't get my key out.
I am in the process of replacing my front drive shaft. I had shifted the transfer case into neutral so I could get to all the bolts easier. But know I can't get the key to turn all the way to the steering lock position, and my battery got drained from the key being stuck on. Please help.
Mike
2002 disco
120,000
Old Oct 11, 2010 | 05:27 PM
yloDiscoII's Avatar
Maybe these are dumb/obvious questions but since you didn't specify either way.......Is the transmission in neutral? Did you try wiggling the steering wheel back and forth?
Old Oct 11, 2010 | 05:36 PM
Davis1978's Avatar
6th Gear
Rob,
Thanks. Yeah it wasn't fully in low of high. After I got it fully into low, I was able to get the key out. I never would have thought that would make a difference. Maybe I wasn't holding my tongue right.
Mike
Old Oct 11, 2010 | 05:39 PM
yloDiscoII's Avatar
Good stuff....It's amazing how finicky these trucks can be
What kind of drive-shaft are you putting in?
Old Oct 12, 2010 | 08:37 PM
Davis1978's Avatar
6th Gear
I ordered a ToddCo. Do you have a source of supply for the nuts and bolts. The nuts got pretty torn up when I took them off. And if I'm putting on new nuts then I figured I'd replace the bolts too. Are they something I can get at a auto parts store, provided they are a equal or stronger grade? Thanks.
Mike
Old Oct 12, 2010 | 09:40 PM
lordmorpheus's Avatar
I got my properly hardened nuts from a hardware store.
no comments please.
Old Oct 12, 2010 | 10:04 PM
mwindth's Avatar
Originally Posted by lordmorpheus
I got my properly hardened nuts from a hardware store. no comments please.
LOL...sorry, I could not help myself...does a good laugh count as a comment? LOL, that was funny.
Old Oct 13, 2010 | 11:10 AM
Fireman's Avatar
Davis1978, I recently made this change too. I used grade 8 bolts with locking nuts. If you dont use the locking nuts, be sure to use loktite.
Old Oct 13, 2010 | 06:47 PM
Claws's Avatar
I'm not even going there.
Old Oct 13, 2010 | 07:59 PM
Davis1978's Avatar
6th Gear
Thanks for the replies and the laughs.
Mike
southfloridadiscoII
Oct 27, 2014 09:36 AM
Lowell
Jul 15, 2012 03:02 PM
southfloridadiscoII
Nov 7, 2011 08:10 AM
starcraft
Mar 18, 2008 09:42 PM
timjescol
Mar 7, 2005 09:16 PM
