HID Extra Headlight detailed installation
#21
Hi Simann,
Those D2R bulbs look interesting. Looks like it has a black shielding coating on the glass bulb. I assume that helps cut down on the glare. Also looks like it requires an adaptor to fit the standard plugs on the ballasts. I would be interested to see it side by side in my setup with what I have now in the driver's headlight and a D2R bulb in the passengers. The D2R bulb looked keyed similar to the H7 bulb slot I require.
What is the cost of converting a reflector style as I have on my 2003 to a projector? Can it be aimed to project a wide path as I have now? I really like my current setup, but I am always open to hear from people who know more than me.
http://www.google.com/imgres?imgurl=...w=1280&bih=587
#22
![Wink](https://landroverforums.com/forum/images/icons/icon12.gif)
You can buy adapters to fit D2R bulbs in a D2S housing, they are like $20 a pair. D2R do cut down on glare, they are made for cars that have HID's but do not have projector housings. (2001 Acura CL, early 2000 Mercedes and such).
As well, I would highly suggest you purchase a lower K (kelvin) temperature bulb, 5000K is way too blue and does not give you maximum light output, just a color. OEM is between 3000-4000 K, this will also cut down on the glare factor but still give you that crisp-clear look that you want with HID's.
I will be doing an install sometime soon, I will let you know the parts I use and how I do it. ( I doubt I will retrofit projectors in the housings of my 03', the used pairs of headlamps for these models are way to pricey to have fun with)
#23
