Hig Temp and chasing "the waterfall"l now..
Old Feb 3, 2016 | 10:25 AM
  #61
abran's Avatar
Rear of the engine is either the heater core fittings(you hope) or a coolant passage at rear of the head gasket.
If you have been bleeding this much and still have the waterfall, there is a leak. I bleed ONCE and never go back unless there is a leak.
Get under the car and look at the back of the heads and below.
Old Feb 3, 2016 | 10:45 AM
  #62
drowssap's Avatar
borrow or rent a pressure tester so that you can find your leak, there are also core plugs in the rear of the heads. iirc
bring your system up to 20 psi and see if it will hold it for an hour or so
jycsalas
May 23, 2019 03:02 PM
99DiscoFlyer
Nov 19, 2015 12:52 AM
lipadj46
May 3, 2010 07:45 PM
Trooper
Jun 26, 2008 08:18 PM
