High Flow Catalytic Converter part number needed
Old Oct 19, 2017 | 07:45 PM
Frank4's Avatar
Default High Flow Catalytic Converter part number needed
Looking for answers from someone that has experience in this area. I've searched the forums and only come up with the Magnaflow cat back system. I am not going that route. I would like to source converters that are direct fit weld ins. As in cut the old ones out and weld the new ones in with little to no mods needed to make them fit.
If you have installed universal high flow cats on your disco and they actually fit with no modification please let me know the part number. I don't mind universal fit, I just want to hear from someone that has done it and had good results.
Thanks
Old Oct 19, 2017 | 10:24 PM
Alex_M's Avatar
Any old universal cat, 2.25" is as close as you're going to get to the factory 2.125" pipe. Real oddball size.
None will be a perfect fit, but they'll all weld in fine. Also, every cat converter produced since the 90s has been "high flow"; even factory catalytic converters are "high flow".
I'd recommend the Walker universals because they're pretty cheap and get good reviews. I have the magnaflows, but if I ever end up replacing them I'll be putting the walkers back. Haven't had great luck out of the Magnaflows honestly.
Old Oct 20, 2017 | 10:15 AM
Frank4's Avatar
You got a part #?
Old Oct 20, 2017 | 12:04 PM
Alex_M's Avatar
Not on hand. You can easily find it on Advance Auto's website though. They've probably got the best price on them, too, once you use the online discount. You can usually find a 20% or 30% off code online.
djkronik57
Mar 29, 2017 10:22 PM
redmanxi
Mar 8, 2014 07:41 PM
MuddMouth
Apr 24, 2013 09:44 AM
RichardBoutwell
Mar 18, 2013 06:38 PM
jdhuegel1
May 6, 2008 06:09 AM
