How to change Crankshaft position sensor 2000 DII
Old Oct 23, 2023 | 09:24 PM
  #71
disco_nap's Avatar
I started to replace mine today. I spent a good two hours trying to attach the wire to the harness. I gave up in frustration (and it got dark). None of the videos online seem to cover this part of it. I can't fit my Popeye arms up there to reattach them... Is it supposed to go in that little clip after you attach the two ends?
Old Oct 23, 2023 | 10:46 PM
  #72
Harvlr's Avatar
Some good photos here. Scroll to post #9
https://landroverforums.com/forum/di...riving-119131/
Old Oct 24, 2023 | 06:23 PM
  #73
adolfojbonilla's Avatar
...I know your pain ...someone ended up cutting a window by the wheel well to easily access it, I'll look for the link since it was a pretty good hack.
Old Oct 24, 2023 | 07:09 PM
  #74
Extinct's Avatar
Don't worry about clipping the harness in to the bracket. Just connect the new sensor to the harness then bolt it to the engine.
Old Oct 25, 2023 | 12:44 PM
  #75
disco_nap's Avatar
Thanks, yep, I found that. I think I may have to go that route. I tried 11" bent needle noses and attacking it from above and below.
If I just had two more inches... story of my life.
Old Nov 10, 2023 | 07:07 PM
  #76
Livinginthe80s's Avatar
6th Gear
Default please share your technique
Originally Posted by Dan7
Done this twice, by myself, without dropping the exhaust. It's another example of "why the @#$$ didn't LR"..."make the harness 2" longer" (in this case). But I've got it down to an hour and unplug/plug in the pigtail 1-handed (no gloves) works best for me. Just takes patience.
Mine wasn't bad, was just going on a road trip and didn't want to rely on a 9 year old part known to fail. Kept the old one as back-up.
Hi, curious how did you unplug it? Coming from the top or from the bottom. The wiring is so short I can't get my hands in there to disonnect. the bracket is in the way coming from the bottom.
Old Nov 10, 2023 | 07:11 PM
  #77
disco_nap's Avatar
I did it from the top, and I also used the 24" version of this:
Amazon Amazon
Which, coincidentally, is also how I broke the clip
Old Nov 10, 2023 | 07:26 PM
  #78
6th Gear
okay... I may try these
16" long needle nose pliers 16" long needle nose pliers
. This is like surgery. I don't know how anyone does this replacement out on the trails.
Old Nov 10, 2023 | 07:40 PM
  #79
disco_nap's Avatar
Just be careful. Like I said, I broke mine. This clip from the harness that you need to plug the sensor into is why my disco is at the mechanic's and will cost me $800 on Monday.
Old Nov 10, 2023 | 09:52 PM
  #80
Brandon318's Avatar
What tools should be bought ahead of time to make this job do-able on the trail? Sounds like long needle nose pliers? Bent? Straight? Length? One pair? Two pairs?
