How to make a cold air intake, by request.
Old Aug 16, 2015 | 10:32 PM
  #31
Charlie_V's Avatar
Originally Posted by Alex_M
It was such a quick change in temp that I'd bet money that it was because of the lack of air movement in the engine bay. When you're moving there is a lot more air coming through your grill (especially my mesh grill) so it's not really pulling what you would consider "engine bay air". So no, I don't think it has much to do with radiating heat from the engine/manifolds to the aluminum pipe, but much more to do with how much air flow there is through the engine bay.
Also, I'm almost positive that the temp is measured at the MAF because if it was measured in the throttle body the radiating heat from the engine and throttle body would throw off the readings, though I have no real evidence to back that up.
I googled it and you are absolutely correct! It is in the MAF. Our MAF is actually a MAFIAT... and will never be called that. http://workshop-manuals.com/landrove...ment/page_385/
Old Aug 16, 2015 | 11:17 PM
  #32
chubbs878's Avatar
Yep, 6 inches should be perfect!
That's what she said.
Old Sep 21, 2015 | 09:15 PM
  #33
Joemamma1954's Avatar
I did mine in Blue, to match my blue Kingsborne wires(that you can't see, haha)
Old Sep 22, 2015 | 07:33 PM
  #34
Alex_M's Avatar
Looks good, Joe! One thing, I'd be careful about your MAF wire. Looks like it's really close to the serpentine belt. I also see you got the nicer clamps, they look good.
Old Sep 22, 2015 | 08:18 PM
  #35
The wire is close to the belt cover, but since I do not have the air pump or whatever kind of pump that goes there, it is a good 6" inches from the belt. I ordered the blue tubes off eBay and the clamps came with them 22.46 total price for hoses and clamps. I used a 4" aluminum intake tube off eBay also and it was 16.48. Got the air filter from Advance Auto and used coupon code for 30% off and had 10.00 in their perks. total price was 42.00. Thanks for the write-up, and the nice words.
3 25" 4 Ply 90°ELBOW Turbo Intercooler Intake Silicone Coupler Hose T Clamp Blue | eBay
3 25" 4 Ply 45°ELBOW Turbo Intercooler Intake Silicone Coupler Hose T Clamp Blue | eBay
3 25" OD x 4" HPS 6061 Aluminum Joiner Tube Piping Pipe w Bead Roll for Intake | eBay
Old Sep 22, 2015 | 11:25 PM
  #36
Alex_M's Avatar
Thats awesome, and hell of a price! I paid more than that for just the filter
Quite welcome, my friend. Glad I could help.
Old Sep 23, 2015 | 10:03 PM
  #37
chubbs878's Avatar
I'll double check the 6 inches real quick.
That's expensive! Jeez! I paid $68.
That AEM actually won't work. The inlet side of the MAF is actually a different diameter than the outlet side and the throttle body. What I did was I just walked in O'Reilly with my MAF and said I needed a K&N that would slip right on, so I'm not actually sure of the diameter.
Do you also say "actually" in every freaking sentence when you are speaking as well?! That's ridiculous!
Old Sep 23, 2015 | 11:21 PM
  #38
Alex_M's Avatar
Actually, I don't actually think I actually do that in person. I might actually be wrong, but I actually don't think so.
Old Sep 23, 2015 | 11:48 PM
  #39
chubbs878's Avatar
I hope not you weirdo! Was I the only person to see karlee Jenners new butt pic today!?! I think it was on TMZ. S o a B that chick is bad. I can't shake it from my head. Yall should look it up. It's a photo of her from the back wearing like a 1-piece bathing suit. Whewwwww
Old Sep 24, 2015 | 08:40 AM
  #40
OffroadFrance's Avatar
I am looking into introducing a feed from my A/C climate control ducts into the intake after the MAF but effectively cooling the intercooler more on hot summer days. I am experimenting on the D2 first before going for the other trucks. IF it works OK I'll post the results but it'll take a dyno run to verify any improvements per se. I'm not looking for additional power but improved hot running intake charge improvements. The duct will no doubt need a shut off flap for winter conditions.
