I have the symptoms, can you ID the source?
Old Oct 1, 2012 | 07:36 PM
innzane's Avatar
Default I have the symptoms, can you ID the source?
I still have a gremlin showing it's self on occassion.
So I thought I would list the symptoms to see if they all might come from one source, like the BCU or fuse box.
Things that do not work when it happens.
Front power windows
light around key hole
gear shift release solenoid
turn signals
courtesy lights
And on less occassion
will not crank
M+S lights on dash
Gear selector LED shows all symbols
Only leak I can find is the sunroofs, anything up in the ceiling that could be suspect?
Any good write ups on sunroof leak fixes?
Thanks again RG's
Old Oct 1, 2012 | 08:46 PM
ZGPhoto's Avatar
What does your battery output look like? How long since you put a new one in?
Old Oct 1, 2012 | 09:45 PM
innzane's Avatar
Hi. Battery is good, I have tried a new one. Truck runs and works fine, when it works.
Old Oct 2, 2012 | 12:20 AM
Sounds like a bad ground in one or more spots. Break out the circuits guide and look for grounds that support several of those items. Also follow big black wire from battery and be sure the chassis ground spots for it are clean and tight.
Old Oct 2, 2012 | 10:07 AM
innzane's Avatar
Thanks SB, is the circuit guide in the rave?
calebbo
Oct 12, 2011 09:54 PM
Disco2Fever
May 5, 2010 01:13 PM
humroot
Oct 25, 2009 05:37 AM
mgabriel
Dec 3, 2008 05:17 PM
wsmc923
Sep 25, 2008 10:25 AM
