I'm about to dive into head gasket replacement any ideas?
ok....
ok....
Yes, have machined..just enough to make sure dead flat..
Yes head bolts as they stretch..you can use studs and they don't stretch cost over twice as much.. Used on one of my disco's worked great..
You would have to pull the motor and have a machine shop check to see if they find any evidence of slipped sleeve.
To cover your base's make sure your first stop is a liquor store as it numbs the pain and aggravation of owning one of these piles...
I'm losing coolant and overheating. I have no external leaks but I keep overheating. We have checked the radiator and it is properly cooling. Pulled the water pump and it is fine too. The problem has gotten worse over the last month to the point that the truck overheats in about 15 minutes. Even on cool mornings.
I'm in Denver too, if you have any ideas it would be most appriciated.
2003. I honestly have no idea where the coolant is going, she isn't smoking but I'm losing coolant quickly.
MR Glassman,
I am in Boulder.
You most likely need to get the head gaskets replaced.
I had this exact same problem..
There is a shop in Boulder who will replace the heads with heads which have been milled and valves all refitted for $2,000.
Arapahoe Imports on Arapahoe in Boulder.
I decided to do it myself in the parking lot.
Key was to have a good car battery, an inverter and a light for night work.
You will need:
Head gaskets
Intake gasket
Head bolts.
You may need exhaust studs if you break one.
Here are some pictures I took in the parking lot.
This took me a good two weeks. I work pretty slowly the first time on the Discovery II..
Flickr: Landroverdude2's Photostream
Best,
J
I am in Boulder.
You will need:
Head gaskets
Intake gasket
Head bolts.
Best,
J
bennyb43
11-28-2015 04:01 PM
lipadj46
06-24-2009 03:21 PM
