installing my magnecors as we speak. coil end has different connector
Old Feb 12, 2010 | 05:09 AM
elboy0712's Avatar
Default Suede I dont have a cap i have coils
there is no distro cap on my truck its got coils ......
Old Feb 12, 2010 | 12:58 PM
okdiscoguy's Avatar
if you post the year of your truck, I can give you the # to cross to..
Old Feb 12, 2010 | 01:10 PM
AK Rover's Avatar
Originally Posted by Alex J
FYI the thickness of a plug wire does not change how it performs. The center conductors that carry the spark are the same size in a 7mm wire as they are in an 8mm wire. The 8mm wire has thicker insulation is all. If you build a lot of under hood heat like a turbo one you will see a difference in performance once the engine got up to temp.
We have done dyno tests at the BMW shop I work at and on the older cars that still use a plug wires we saw zero difference in lap times or power between new OE 6.5mm wires and performance 8mm wires.
Electricity actually runs on the outside of the wire wraps, not the core. Therefore with a larger diameter the 8mm is capable of carrying a larger current than a 6.5 or 7mm due to the larger surface area. If using an ignition system designed around 6.5mm wires it is only going to put out current designed for 6.5mm wires so of course the current isn't going to change with 8mm wires, only the potential to carry more current will change.
I know for a fact that 8mm wires do make a difference on these Rover engines. If you want to discuss BMW you need to go to another forum. Anything that happens with a BMW has nothing to do with Rovers and is just useless information.
celm
Apr 19, 2011 09:14 PM
dynomite
Aug 20, 2009 11:35 PM
starcraft
Apr 7, 2008 08:17 PM
starcraft
Mar 21, 2008 12:47 PM
Off Topic
Feb 25, 2005 07:33 PM
