Issues with New O2 Sensors
Old Oct 17, 2012 | 11:42 AM
  #31
jfall's Avatar
That's a good catch.
If the pins got bent when you cleaned them and then the plug went in-
one would get flattened.
But, if you have the scanner on and can see the O2 sensors oscillating up and down - then no need to take it apart.
Old Oct 17, 2012 | 11:44 AM
  #32
Alan Phillips's Avatar
Originally Posted by jfall
Yeah, sorry. I just thought you were blowing me off.
I did not catch you checked the heater fuses.
I get frustrated when there are tons of replies all over the place
It's all good J, your advice in past threads has helped me out immeasurably. I figured it was just a misunderstanding. I do see where a lot of advice is ignored and can see where it would be frustrating.
Old Oct 17, 2012 | 09:27 PM
  #33
Got it all back together and it seems to be working fine. The O2 graphs look like they should. Thanks to everyone for their advice.
A recap of what I did:
Replaced both front O2 sensors
Changed the fuse to the emissions stuff
Disconnected the battery while I changed the sensors
Did NOT use dielectric goop this time
Wiped out each connector with a dry Q-tip
Poured a can of Seafoam in and filled up the tank from a different gas station that is off the freeway.
Old Oct 18, 2012 | 01:58 PM
  #34
jfall's Avatar
Clear the codes and try again.
Need more operational data.
Old Oct 19, 2012 | 05:07 PM
  #35
There are no codes to clear. It works like a charm again.
Old Oct 19, 2012 | 05:46 PM
  #36
jfall's Avatar
Yeah!
Way to go.
celebrate!
Old Jun 10, 2013 | 07:25 PM
  #37
Leej's Avatar
Default O2 sensor problems...
Hi all
I'm having similar problems with new O2 sensors.
2000 Discovery, with 90,000 miles. I just replaced both upstream O2 sensors with Bosch (black box from Amazon with orange OEM connectors), and then after 15 miles or so I'm now getting the following codes:
P0130
P0150
P1129
P0174
P0171
P1174
P1171
I've checked the connectors and spayed them with contact cleaner, I don't believe they are dirty or getting oily. I can't find any vacuum leaks. Didn't see any wiring issues. Checked fuses and didn't see any bad ones (although I'm not sure which fuse is related to O2).
When I watch the O2 status on a code reader, it is changing, but not by much, seems to stay around .2 for both sensors?
Any ideas?
Lee
Old Oct 16, 2019 | 05:44 PM
  #38
GarySpringfield's Avatar
Default Bosch from Amazon
Originally Posted by Alan Phillips
The sensors I bought are exact fit for the Discovery, the part number is the same as listed on Amazon and referenced through the forum. They were in Black Bosch boxes and came with a warranty. It sucks they crapped out a day after putting them in, but these sorts of things happen.
I doubt there is a corporate conspiracy at Autozone to sell defective or incorrect parts to everyone who doesn't drive a Ford or Chevy.
Thought I'd pass along, I got my Bosch Black Box sensors locally, but my buddy with a D2 got his from Amazon, had a dead one, went online to "My Orders" and filled out a return product form, and they replaced his sensor the next day, right to his door. The new one worked fine. another user here likes Walker...I've got one coming but haven't tried it yet.
Garrett
Feb 15, 2011 06:45 PM
2000 DII
Nov 1, 2010 01:01 PM
G4AKumar
Apr 29, 2010 02:08 PM
RedAustinIX
Mar 12, 2010 09:50 PM
audioclay
Oct 29, 2009 08:49 PM
