just dies
Old Mar 15, 2015 | 07:40 AM
ralphobell's Avatar
Originally Posted by Doc McCoy
you'll have to pardon me but how is it a Rover Master Tech doesn't know my vehicle doesn't have a distributor? I am not a mech that's why I'm here looking for help. No it has never thrown a code with this issue. I went and tried to start it after a cool down period last night and no joy. While trying to start the check engine light does go out if that is any help. Yes it was and OEM cps.
He was being an ars and being sarcastic. I would suggest downloading the RAVE which is a repair manual. Also download the owners manual. Read them over so you can get familiar with your vehicle. Spend some time on here searching and reading some of these threads. Lots of great info on here.
Owning a D2 you will need to learn to be a shade tree mechanic if you want to keep these things operating. Many users on here started not knowing anything about cars and have become quite proficient at wrenching.
Old Mar 15, 2015 | 07:50 AM
Doc McCoy's Avatar
how do you check that? Could it be a coil issue or would the coils make it just die like that?
Old Mar 15, 2015 | 07:52 AM
Doc McCoy's Avatar
thanks ralph
Old Mar 15, 2015 | 07:53 AM
dusty1's Avatar
Coil will usually throw Misfire codes and cel
Old Mar 15, 2015 | 07:55 AM
dusty1's Avatar
Fuel rail has a shrader valve attached to it. You can put a pressure tester on there and check
You can see valve sticking out the back
Old Mar 15, 2015 | 01:54 PM
Two Rock's Avatar
If you have a harbor freight tools near you u should be able to get both a spark tester and a fuel pressure tester for less than 30 bucks, even less if u use a 20% off coupon thru always offer
Old Mar 15, 2015 | 02:04 PM
RoverMasterTech's Avatar
Very simple. Hook a scan tool up and check rpm while cranking. if you have rpm its a fuel problem.
Old Mar 15, 2015 | 08:46 PM
Doc McCoy's Avatar
Well thank you guys for all your help. I let them tow it to the dealer today. I wish my hands were twenty years younger but my osteoarthritis in both hands makes it almost impossible to do much wrenching these days. I will certainly give you a follow up when I hear what they have to say. Again thanks
Old Mar 16, 2015 | 11:49 AM
jfall's Avatar
Believe it or not..
Can just die if the O2's are acting up.
Or the SPEED SENSOR is acting up.
This happens at interstate speed sometimes even.
Jerks and sputters.
Put a code reader on the OBDII and check codes.
Even no check engine light - there can be PENDING codes.
Old Mar 18, 2015 | 12:29 PM
Broken08's Avatar
Any word? Dying to know
