just my findings..03 disco head gasket job
I'm in the middle of doing both head gaskets. The ONLY reason I'm doing them is because I tore the engine down to do lifters. Figured I'd do it while I was in there... I got AB's head gasket set with the composite gaskets. When I pulled the heads I found that BOTH head gaskets were leaking at BOTH ENDS of each head. I've been losing just a little coolant over maybe a thousand miles. Maybe a little less. Nothing of concern. I just figured there's so many leaks on the thing it was just a really small leak some where hardly noticeable. Boy was I wrong. All 4 coolant ports had been leaking. You can't even see the signs of leakage on the rear of the heads until you pull them. What amazed me was when I broke free the very first head bolt from the front driver head, instantly coolant starting running out between the head and block. All I did was turn the head bolt about 1/4" in the loosen direction. 3 of my lifters had not been spinning in their bores and were extremely worn. That was my cold engine knock. I also found that 4 of my exhuast valve seats were so corroded that I can't even imagine how they were sealing. Anyways... just thought I'd post this incase any one else is losing a small amount of coolant and can't find a leak. I didn't even suspect them to be bad. Engine ran fine other wise. If all the ports were leaking front, rear, pass side and driver I imagine a lot more out there are too....
