Just replaced my spark plug wires
Old May 4, 2018 | 11:33 AM
  #21
Sixpack577's Avatar
I left the pipe on the front of the lower intake, it can stay on when you remove the lower intake.
As for the sai and upper intake, the sai tubes flex, I removed the 2 nuts holding each and pulled them off the studs, 6 bolts hold the upper intake on, and the coil bracket needs loosened or removed first, but as said, an easy job.
Old May 4, 2018 | 11:34 AM
  #22
Sixpack577's Avatar
Originally Posted by Saturnine
Hmm.. well whatever.
I had to take it off / loosen it when doing my stuff so maybe my truck is just MORE difficult than yours lol
Your truck must be a female.
Old May 4, 2018 | 02:00 PM
  #23
Saturnine's Avatar
Its possible.
For me, there was flex in the SAI stuff but it wouldn't budge another 1/8" to clear the studs that are on the upper IM -- which is why i had to unbolt that coolant pipe.
Old May 4, 2018 | 02:07 PM
  #24
Best4x4's Avatar
If the studs are your problem, slap on two nuts back to back and then remove the stud. As long as you get one side of studs off you can angle the intake out no problem. With the intake out then remove the studs & just use bolts from then on.
Old May 4, 2018 | 02:08 PM
  #25
Saturnine's Avatar
Thanks for telling me that now after all the work is done.
Old May 4, 2018 | 02:52 PM
  #26
Best4x4's Avatar
No one asked me lol
Old May 4, 2018 | 02:54 PM
  #27
acg's Avatar
acg
This guy's coat hanger trick on Youtube is pretty cool. I will have to try it on my next wire update project.
Old May 4, 2018 | 06:46 PM
  #28
Jeff Blake's Avatar
OK so removing the intake is not the worst job, but I imagined life for a moment without this:
fishing for the lower coil pack bolt
With A/C deleted, this is a "free" mod. I think its a no brainer. I'll just need some wiring extensions for the engine harness and some brackets, and good to goooo
I see no downside whatsoever
Does anyone know the name of the coil pack wiring connector?
mikedemet
Jan 29, 2021 02:02 PM
bigugly82
Aug 28, 2007 04:06 PM
Darover
May 22, 2007 08:46 AM
mikedemet
Mar 7, 2006 12:07 AM
kfordric
May 30, 2005 11:29 PM
