KER CLUNK
Old Feb 15, 2008 | 04:26 PM
EL GALLO's Avatar
Default KER CLUNK
HELLO GUYS
MY 2004 DISCO HAS A CLUNK SOMETIMESIF DECELERATE AND THEN ACCELARATE INMEDIATELY.IT HAS ONLY 20125 MILES ON IT. CAN IT BE U JOINT ISSUES?THANK YOU .
Old Feb 15, 2008 | 04:36 PM
NWDiscoRover2004's Avatar
Default RE: KER CLUNK
sounds like slack in the drive train somewhere. u-joints, pinion clearance or ??
Old Feb 15, 2008 | 04:51 PM
Other then how well you maintane your u-joints, there is always a clunk as you described. Have you greased your u-joints, have your replaced the 2 non servicable u-joints in your front drive shaft?
Old Feb 15, 2008 | 04:58 PM
jkid's Avatar
That's not a lot of miles. If it was the u-joints you should be able to feel any play in them if they were clunking like that. The best way to check is to raise the front wheels off the ground so that the driveshaft can turn free, grab each side of the joint and try twist it in opposite directions feeling for the slightest amount of play. I notice a quiet klunk when I let off the gas and then get on it, I think it was more so with my cdl engaged. That seems normal.
Old Feb 15, 2008 | 05:12 PM
EL GALLO's Avatar
THANKYOU ALL.FEEL A BIT RELIEVED. WILL CHECK ANYWAY AS DISCRIBED.
Old Feb 15, 2008 | 06:43 PM
Camdisco24's Avatar
I'm pretty sure there is a natural clunk like that when you let of the gas around 30-35, or anywhere close to where the gears change. I noticed it too but realized it was just a normal sound. And my U-joints are perfect. I would say dont worry about it unless you feel its unnatural or more of a grinding sound.
Old Feb 16, 2008 | 10:11 AM
jkid's Avatar
ORIGINAL: Camdisco24
Goodpoint. Noises arevery hardto describewithout actually being there and hearing it, only you know for sure. Or take it to somebody who knows.
DiscoMike2003
Nov 13, 2008 04:57 PM
Airwolf1
Nov 13, 2006 03:42 PM
Airwolf1
Nov 11, 2006 10:36 PM
msbont
Sep 10, 2006 03:53 PM
bmartin2
Feb 18, 2006 02:49 AM
