Key will not turn
Old Feb 9, 2008 | 10:58 PM
AK's Avatar
AK
Default Key will not turn
I have a 2000 Disco, I went out to start it today and the key does not turn. I have never had this problem before. The battery is fine, any suggestions.
I'm thinking its an alarm thing.
Old Feb 10, 2008 | 06:09 AM
Different Drummer's Avatar
Default RE: Key will not turn
That happened to mine last year and I had to order a new switch. They're pretty pricey if you order a new one coded to match your remote/key combo, so I hope you can wiggle it enough to make it turn. Keep in mind that if you just order a different switch then it won't work with your remote key, so you'll have to still carry the old key to unlock the doors. To avoid that, I sent in the old switch and had Land Rover send me a new switch programmed to work with my old key so everything still works with it. It took a few weeks so my mechanic put in a used switch he had to get me going until the new switch came in. I hope you don't have to go through all that though,because it's an expensive PITA.
Old Feb 10, 2008 | 09:03 AM
This sounds stupid but it happened to me before with a Ford, turn the key over. With double sided keys one side will wear more than the other because you use it more not even realizing it and then it will not work. Turn the key over and it works.
In my case I had a second key made and one of the sides wasnt right and it didnt work.
Good luck.
Old Feb 10, 2008 | 09:16 AM
It is not the alarm.
So if I read this right, you can get in thru the drivers door lock just not turn the key???
Is the steering wheel locked, have you tried turning the wheel hard left or right while turning the key??
molly
Jun 12, 2020 01:34 PM
BIGTSV
Jul 31, 2013 05:36 PM
Disco SoccerMom
Jan 15, 2009 11:35 AM
ccvalentino
Jan 11, 2009 08:09 AM
mrmozambique
Aug 23, 2006 03:34 PM
