Key Will Not Turn
Old Jan 11, 2009 | 06:12 AM
ccvalentino's Avatar
Default Key Will Not Turn
Hi,
I have a 2000 Landrover Discovery 2.
Non-regularly my key will not turn. I have no trouble putting the key into and taking out of the ignition, typically when this happens eventually the key turns. It may be related to the alarm (however I'm unsure), some times if I accidentally push the wrong combo of keys on the key the alarm goes off. Does the rover lick the ignition? If so is there some time limit it remains locked?
Any insights you may have would be greatly appreciated.
Chris
Old Jan 11, 2009 | 08:09 AM
tomfraser's Avatar
Default RE: Key Will Not Turn
try turning the wheel back and forth as much as you can (it should be locked) as you are turning the key
molly
Jun 12, 2020 01:34 PM
BIGTSV
Jul 31, 2013 05:36 PM
Disco SoccerMom
Jan 15, 2009 11:35 AM
AK
Feb 10, 2008 09:16 AM
mrmozambique
Aug 23, 2006 03:34 PM
