Know anything about replacement for plastic trim around water drain, sides of roof?
Old Feb 13, 2014 | 03:33 PM
earlyrover's Avatar
Default Know anything about replacement for plastic trim around water drain, sides of roof?
During ice storm, I had two sections of my plastic roof water drain trim, around outer perimeter of water drain, broken from ice falling off trees. So, what does one use to replace that broken plastic trim, is another new trim section available; if so, where, and for how much?
Old Feb 13, 2014 | 03:44 PM
ZGPhoto's Avatar
Some of it is NLA, which pieces specifically? You could call Marty powell/paul grant/will tillery for a used piece on the cheap.
Old Feb 13, 2014 | 04:51 PM
earlyrover's Avatar
"which pieces specifically?"
______________________
Hard to describe, but the plastic water trough on driver's side, back close to rear side window (not the rear door window), where black plastic water trough seems to be snapped on inner metal trough when originally mounted there; that area is where the plastic broke off.
Old Feb 14, 2014 | 11:29 AM
SuperSport's Avatar
Here are the part numbers:
And, I'm guessing THIS is the one you are looking for???
DBC101410 | GUTTER TRIM L/H/R SIDE DIS11 | Land Rover | Discovery 2 - 1999 to 2004 | Britcar (UK) Ltd
Attached Thumbnails Know anything about replacement for plastic trim around water drain, sides of roof?-drip-rail-mouldings.jpg   Know anything about replacement for plastic trim around water drain, sides of roof?-drip-rail-mouldings-1.jpg   Know anything about replacement for plastic trim around water drain, sides of roof?-drip-rail-mouldings-2.jpg   Know anything about replacement for plastic trim around water drain, sides of roof?-drip-rail-mouldings-3.jpg   Know anything about replacement for plastic trim around water drain, sides of roof?-drip-rail-mouldings-4.jpg
Old Feb 14, 2014 | 01:25 PM
earlyrover's Avatar
SuperSport, Spot on; thank you so much for the help.
aftermath431
Feb 27, 2014 11:48 AM
starcraft1
Jun 14, 2011 08:35 PM
yarddawg
Jun 14, 2009 04:50 PM
ucfmethod
Jul 21, 2008 08:42 PM
ronev
Jun 20, 2006 01:43 AM
